Hi, I’m doing research on the best telemetry system. Currently, I’m starting from this guide https://chapeter-sbx.readthedocs.io/en/latest/labs/metrics-grafana/ and I would like to replace pipeline with telegraph for more input compatibility. I’ve found this https://ultraconfig.com.au/blog/cisco-telemetry-tutorial-with-telegraf-influxdb-and-grafana/ which uses telegraf but its using the yang encoding in the switches instead of nx-api (as in the first guide).
The question is: how can I parse the data in telegfraf from nx-api format before sending them to influxdb like pipeline which is using metrics.json?
Ps: I’m not an expert and this is all new for me (edited)
Hello @stefanoromanello,
Welcome!
Have you had a chance to take a look at the execd processor plugin?
I think that might be helpful to you.
Hi thanks for the answer! Another user in slack suggests me to use telegraf_gnmi and use it also for parsing the data like this:
[[inputs.cisco_telemetry_gnmi]]
addresses = ["dallas.create2020.ntc.cloud.tesuto.com:50000"]
username = <redacted>
password = <redacted>
## redial in case of failures after
redial = "10s"
tagexclude = ["openconfig-network-instance:/network-instances/network-instance/protocols/protocol/name"]
[[inputs.cisco_telemetry_gnmi.subscription]]
origin = "openconfig-interfaces"
path = "/interfaces/interface"
subscription_mode = "sample"
sample_interval = "10s"
name = "bgp_neighbor"
origin = "openconfig-network-instance"
path = "/network-instances/network-instance/protocols/protocol/bgp/neighbors/neighbor/state"
Full guide at Monitor Your Network With gNMI, SNMP, and Grafana | The NTC Mag
What do you think?
looks good to me!
