I have this JSON response that I would like to parse to a flux table:
{"body":{"1690727139":[0.059],"1690730739":[0]},"status":"ok"}
The body object contains thousands for records.
Ideally I would do something like:
foreach ($json->{'body'} as $key => $value) {
$arr[] = array("_time" => $key, "_value" => $value[0] );
How can I do this in flux?
This is my best attempt: (but record.get for every row is not ideal)
import "array"
import "experimental/json"
import "experimental"
import "experimental/record"
jsonStr = bytes( v: "{\"body\":{\"1690727139\":[0.059],\"1690730739\":[0]},\"status\":\"ok\"}")
data = json.parse(data: jsonStr).body
experimental.objectKeys(o: data)
|> array.map(fn: (x) => ({_time: time(v: uint(v: string(v: x) + "000000000")), val: display(v: record.get(r: data, key: x, default: [0])[0])}))
|> array.from()
