Hi
I’m trying to run ‘flux’ command line tool to test my scripts without InfluxDB.
Here is a minimal script:
import "csv"
data = "
result,table,_start,_stop,_time,region,host,_value
mean,0,2018-05-08T20:50:00Z,2018-05-08T20:51:00Z,2018-05-08T20:50:00Z,east,A,15.43
csv.from(csv: data)
|>yield()
the command ./flux execute @csv.flux is completed successfully, but prints nothing.
Is there anything special to redirect data to STDOUT?
