How to do mean,count and 95 percentile on a single column using flux query
I am new to influx DB , i tried framing flux query which gives output columns as mean, count and 95 percentile on a single column but i didn’t get the desired output, could anyone please help me with flux query
Sql query looks like
select avg(colA),count(colA),95percentile(colA) from _measurement
@Sravs_Sekhar This is how I’d do it:
data = () => from(bucket: "exmaple-bucket")
    |> range(start: -1d)
    |> filter(fn: (r) => r._measurement == "example-measurement")
    |> filter(fn: (r) => r._field == "colA")
avg = data() |> mean() |> set(key: "_field", value: "avg")
count = data() |> count() |> set(key: "_field", value: "count")
pct = data() |> quantile(q: 0.95) |> set(key: "_field", value: "95percentile")
union(tables: [avg, count, pct])
    |> pivot(rowKey: ["_start"], columnKey: ["_field"], valueColumn: "_value")
Thankyou for helping me , i tried the above query but an getting below error could you please do the needful
data = () => from(bucket: “example bucket”)
|> filter(fn: (r) => r._measurement == “measurment” and r.ServiceName == " tag name ")
|> filter(fn: (r) => r._field == “field”)
|> filter(fn: (r) => r[“OrganizationCode”] =~ /^${OrganizationCode:regex}$/ )
|> group(columns: [“OrganizationCode”, “_measurement”], mode:“by”)
avg = data() |> mean() |> set(key: “_field”, value: “avg”)
count = data() |> count() set(key: “_field”, value: “count”)
pct = data() |> quantile(q: 0.95) set(key: “_field”, value: “95percentile”)
|> pivot(rowKey: [“_start”], columnKey: [“_field”], valueColumn: “_value”)
Note: both servicename and OrganizationCode are tags
Below error :
error @8:27-8:61: missing required argument tables error @9:35-9:76: missing required argument tables
Sorry, I had missed some pipe-forward’s (|>) before the set() calls. Try this:
data = () =>
    from(bucket: "example bucket")
        |> filter(fn: (r) => r._measurement == "measurment" and r.ServiceName == " tag name ")
        |> filter(fn: (r) => r._field == "field")
        |> filter(fn: (r) => r["OrganizationCode"] =~ /^${OrganizationCode:regex}$/ )
        |> group(columns: ["OrganizationCode", "_measurement"], mode:"by")
