i got output from http input xml :
burner_data{entryCount="103",entrySize="1324",gpuEntryCount="1",gpuEntrySize="1304",headerSize="32",host="595c9e42f309",signature="1296123981",time="1730547609",url="http://192.168.0.101:82/mahm",version="131072"} NaN
afterburner_data{data="0",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="No load limit",localizedSrcUnits="",maxLimit="1",minLimit="0",recommendedFormat="%.0f",srcId="116",srcName="No load limit",srcUnits="",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="Power limit",localizedSrcUnits="",maxLimit="1",minLimit="0",recommendedFormat="%.0f",srcId="113",srcName="Power limit",srcUnits="",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="Temp limit",localizedSrcUnits="",maxLimit="1",minLimit="0",recommendedFormat="%.0f",srcId="112",srcName="Temp limit",srcUnits="",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="VID usage",localizedSrcUnits="%",maxLimit="100",minLimit="0",recommendedFormat="%.0f",srcId="51",srcName="VID usage",srcUnits="%",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="0",host="595c9e42f309",localizedSrcName="Memory usage \\ process",localizedSrcUnits="MB",maxLimit="11264",minLimit="0",recommendedFormat="%.0f",srcId="53",srcName="Memory usage \\ process",srcUnits="MB",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="0",host="595c9e42f309",localizedSrcName="RAM usage \\ process",localizedSrcUnits="MB",maxLimit="32768",minLimit="0",recommendedFormat="%.0f",srcId="147",srcName="RAM usage \\ process",srcUnits="MB",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="4294967295",host="595c9e42f309",localizedSrcName="Framerate",localizedSrcUnits="FPS",maxLimit="200",minLimit="0",recommendedFormat="%.0f",srcId="80",srcName="Framerate",srcUnits="FPS",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="4294967295",host="595c9e42f309",localizedSrcName="Framerate 0.1% Low",localizedSrcUnits="FPS",maxLimit="200",minLimit="0",recommendedFormat="%.0f",srcId="86",srcName="Framerate 0.1% Low",srcUnits="FPS",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="4294967295",host="595c9e42f309",localizedSrcName="Framerate 1% Low",localizedSrcUnits="FPS",maxLimit="200",minLimit="0",recommendedFormat="%.0f",srcId="85",srcName="Framerate 1% Low",srcUnits="FPS",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="4294967295",host="595c9e42f309",localizedSrcName="Framerate Avg",localizedSrcUnits="FPS",maxLimit="200",minLimit="0",recommendedFormat="%.0f",srcId="83",srcName="Framerate Avg",srcUnits="FPS",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0",flags="SHOW_IN_OSD",gpu="4294967295",host="595c9e42f309",localizedSrcName="Frametime",localizedSrcUnits="ms",maxLimit="100",minLimit="0",recommendedFormat="%.1f",srcId="81",srcName="Frametime",srcUnits="ms",url="http://192.168.0.101:82/mahm"} 0
afterburner_data{data="0.9375",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="Tree V Current",localizedSrcUnits="A",maxLimit="100",minLimit="0",recommendedFormat="%.3f",srcId="255",srcName="Tree V Current",srcUnits="A",url="http://192.168.0.101:82/mahm"} 0.9375
afterburner_data{data="1",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="BUS usage",localizedSrcUnits="%",maxLimit="100",minLimit="0",recommendedFormat="%.0f",srcId="52",srcName="BUS usage",srcUnits="%",url="http://192.168.0.101:82/mahm"} 1
afterburner_data{data="1",flags="None",gpu="0",host="595c9e42f309",localizedSrcName="Voltage limit",localizedSrcUnits="",maxLimit="1",minLimit="0",recommendedFormat="%.0f",srcId="114",srcName="Voltage limit",srcUnits="",url="http://192.168.0.101:82/mahm"} 1
afterburner_data{data="1013",flags="SHOW_IN_OSD",gpu="0",host="595c9e42f309",localizedSrcName="Fan tachometer",localizedSrcUnits="RPM",maxLimit="5000",minLimit="0",recommendedFormat="%.0f",srcId="17",srcName="Fan tachometer",srcUnits="RPM",url="http://192.168.0.101:82/mahm"} 1013
afterburner_data{data="1039",flags="SHOW_IN_OSD",gpu="0",host="595c9e42f309",localizedSrcName="EKWB TOP Radiator Fans",localizedSrcUnits="RPM",maxLimit="2500",minLimit="0",recommendedFormat="%.0f",srcId="255",srcName="EKWB TOP Radiator Fans",srcUnits="RPM",url="http://192.168.0.101:82/mahm"} 1039
afterburner_data{data="1144",flags="SHOW_IN_OSD",gpu="0",host="595c9e42f309",localizedSrcName="Phanteks FRONT Fans",localizedSrcUnits="RPM",maxLimit="2500",minLimit="0",recommendedFormat="%.0f",srcId="255",srcName="Phanteks FRONT Fans",srcUnits="RPM",url="http://192.168.0.101:82/mahm"} 1144
afterburner_data{data="12.25",flags="SHOW_IN_OSD",gpu="0",host="595c9e42f309",localizedSrcName="Twelve V",localizedSrcUnits="V",maxLimit="100",minLimit="0",recommendedFormat="%.3f",srcId="255",srcName="Twelve V",srcUnits="V",url="http://192.168.0.101:82/mahm"} 12.25
to prometheus :
# HELP afterburner_bus_usage_percent
# TYPE afterburner_bus_usage_percent gauge
afterburner_bus_usage_percent{gpu="NVIDIA GeForce GTX 1080 Ti",gpu_bios="86.02.39.00.23",gpu_driver="565.90",gpu_family="GP102-A",gpu_id="VEN_10DE&DEV_1B06&SUBSYS_85EA1043&REV_A1&BUS_101&DEV_0&FN_0"} 0
# HELP afterburner_commit_charge_bytes
# TYPE afterburner_commit_charge_bytes gauge
afterburner_commit_charge_bytes 2.3885e+10
# HELP afterburner_core_clock_hertz
# TYPE afterburner_core_clock_hertz gauge
afterburner_core_clock_hertz{gpu="NVIDIA GeForce GTX 1080 Ti",gpu_bios="86.02.39.00.23",gpu_driver="565.90",gpu_family="GP102-A",gpu_id="VEN_10DE&DEV_1B06&SUBSYS_85EA1043&REV_A1&BUS_101&DEV_0&FN_0"} 1.39e+08
# HELP afterburner_cpu_clock_hertz
# TYPE afterburner_cpu_clock_hertz gauge
afterburner_cpu_clock_hertz{core="1"} 3.600001e+09
afterburner_cpu_clock_hertz{core="10"} 1.5e+09
afterburner_cpu_clock_hertz{core="11"} 1.2e+09
afterburner_cpu_clock_hertz{core="12"} 1.2e+09
afterburner_cpu_clock_hertz{core="13"} 1.5e+09
afterburner_cpu_clock_hertz{core="14"} 1.5e+09
afterburner_cpu_clock_hertz{core="15"} 1.2e+09
afterburner_cpu_clock_hertz{core="16"} 1.2e+09
afterburner_cpu_clock_hertz{core="2"} 3.600001e+09
afterburner_cpu_clock_hertz{core="3"} 1.2e+09
afterburner_cpu_clock_hertz{core="4"} 1.2e+09
afterburner_cpu_clock_hertz{core="5"} 1.2e+09
afterburner_cpu_clock_hertz{core="6"} 1.2e+09
afterburner_cpu_clock_hertz{core="7"} 4.300001e+09
afterburner_cpu_clock_hertz{core="8"} 4.300001e+09
afterburner_cpu_clock_hertz{core="9"} 1.5e+09
# HELP afterburner_cpu_clock_total
# TYPE afterburner_cpu_clock_total gauge
afterburner_cpu_clock_total 4.300001e+09
# HELP afterburner_cpu_core_current_total
# TYPE afterburner_cpu_core_current_total gauge
afterburner_cpu_core_current_total 25
# HELP afterburner_cpu_ekwb_pump_total
# TYPE afterburner_cpu_ekwb_pump_total gauge
afterburner_cpu_ekwb_pump_total 2339
# HELP afterburner_cpu_power_total
# TYPE afterburner_cpu_power_total gauge
afterburner_cpu_power_total 1.450989
# HELP afterburner_cpu_temperature_celsius
# TYPE afterburner_cpu_temperature_celsius gauge
afterburner_cpu_temperature_celsius{core="1"} 40
afterburner_cpu_temperature_celsius{core="10"} 39
afterburner_cpu_temperature_celsius{core="11"} 40
afterburner_cpu_temperature_celsius{core="12"} 40
afterburner_cpu_temperature_celsius{core="13"} 42
afterburner_cpu_temperature_celsius{core="14"} 42
afterburner_cpu_temperature_celsius{core="15"} 44
afterburner_cpu_temperature_celsius{core="16"} 44
afterburner_cpu_temperature_celsius{core="2"} 40
afterburner_cpu_temperature_celsius{core="3"} 38
afterburner_cpu_temperature_celsius{core="4"} 38
