Hi There,
I am new to influx and telegraf. I am trying to configure telegraf to collect stats from cisco switch.
Current configuration --> Works
[[inputs.snmp.table]]
name = “interface”
oid = “IF-MIB::ifXTable”
[[inputs.snmp.table.field]]
name = “ifName”
oid = “IF-MIB::ifName”
Below is the output
interface,agent_host=switch1 ,host=server99 ifName=“fc1/10”,ifInMulticastPkts=0i,ifHCOutUcastPkts=0i,ifConnectorPresent=1i,ifCounterDiscontinuityTime=0i,ifHCInUcastPkts=0i,ifHCInBroadcastPkts=0i,ifHCOutBroadcastPkts=0i,ifPromiscuousMode=2i,ifInBroadcastPkts=0i,ifHCInOctets=24178500939i,ifHCOutOctets=34331953187i,ifHighSpeed=16000i,ifAlias=“Storage_port1”,ifOutMulticastPkts=0i,ifOutBroadcastPkts=0i,ifHCInMulticastPkts=0i,ifHCOutMulticastPkts=0i,ifLinkUpDownTrapEnable=1i 1525669042000000000
But I only need few metrics not all from the table
ifName
ifHCInOctets
ifHCOutOctets
ifAlias
ifHighSpeed
Is it possible to use [[inputs.snmp.table]] and only capture the required metrics ?
is it possible to use [[inputs.snmp.field]] and specify multiple metrics ?
name = “interface”
oid = "IF-MIB::ifHCOutOctets, "IF-MIB::ifHCInOctets “”
If i collect them individually as following
name = “interface”
is_tag = true
name = “bytesIn”
oid = “IF-MIB::ifHCInOctets”
name = “bytesOut”
oid = “IF-MIB::ifHCOutOctets”
how do link them when i am graphing using grafana
Thank You
