2018/11/29 15:16:47 I! Using config file: /etc/telegraf/config.ini
2018/11/29 15:16:47 E! Error parsing /etc/telegraf/config.ini, toml: line 89: parse error
All the other values are default values from github.
# Statsd UDP/TCP Server
[[inputs.statsd]]
## Protocol, must be "tcp", "udp", "udp4" or "udp6" (default=udp)
protocol = "udp"
## MaxTCPConnection - applicable when protocol is set to tcp (default=250)
max_tcp_connections = 250
## Enable TCP keep alive probes (default=false)
tcp_keep_alive = false
## Specifies the keep-alive period for an active network connection.
## Only applies to TCP sockets and will be ignored if tcp_keep_alive is false.
## Defaults to the OS configuration.
# tcp_keep_alive_period = "2h"
## Address and port to host UDP listener on
service_address = ":8125"
## The following configuration options control when telegraf clears it's cache
## of previous values. If set to false, then telegraf will only clear it's
## cache when the daemon is restarted.
## Reset gauges every interval (default=true)
delete_gauges = true
## Reset counters every interval (default=true)
delete_counters = true
## Reset sets every interval (default=true)
delete_sets = true
## Reset timings & histograms every interval (default=true)
delete_timings = true
## Percentiles to calculate for timing & histogram stats
percentiles = [50 90]
## separator to use between elements of a statsd metric
metric_separator = "_"
## Parses tags in the datadog statsd format
## http://docs.datadoghq.com/guides/dogstatsd/
parse_data_dog_tags = false
## Statsd data translation templates, more info can be read here:
## https://github.com/influxdata/telegraf/blob/master/docs/TEMPLATE_PATTERN.md
# templates = [
# "cpu.* measurement*"
## Number of UDP messages allowed to queue up, once filled,
## the statsd server will start dropping packets
allowed_pending_messages = 10000
## Number of timing/histogram values to track per-measurement in the
## calculation of percentiles. Raising this limit increases the accuracy
## of percentiles but also increases the memory usage and cpu time.
percentile_limit = 1000
