hallo @FixTestRepeat, i have been also looking to logs yesterday but here i my today tests:
my time stamp is always unix time / i just use MS instead of NS
with past date i have no issues as for tests i am importing tons of data, more then one year old, especially when moving influx_1 data to influx_2
i have created a test bucket ‘jjj’ to egrep faster in logs. but i do not see any error/warning
my config.toml is set to   log-level = “debug”
see the journal logs below
#no precision set / same curl command as in previous post
#the record cannot be found with query
Jun 02 07:41:42 komar influxd[29321]: ts=2021-06-02T07:41:42.990122Z lvl=debug msg=Request log_id=0TyV~fGl000 service=http method=POST host=XXX:8086 path=/api/v2/write query=“bucket=jjj&org=foookin_paavel” proto=HTTP/2.0 status_code=204 response_size=0 content_length=99 referrer= remote=XXX:36220 user_agent=curl took=82.900ms
#json_log_version
“_COMM” : “influxd”,
“_PID” : “29321”,
“SYSLOG_IDENTIFIER” : “influxd”,
“_TRANSPORT” : “stdout”,
“_EXE” : “/usr/bin/influxd”,
“_SYSTEMD_CGROUP” : “/system.slice/influxdb.service”,
“__REALTIME_TIMESTAMP” : “1622619702990192”,
“_STREAM_ID” : “d1b736cae0744e5da0d78f78ff27887d”,
“_HOSTNAME” : “komar”,
“_SYSTEMD_SLICE” : “system.slice”,
“_CAP_EFFECTIVE” : “0”,
“PRIORITY” : “6”,
“_SELINUX_CONTEXT” : “unconfined\n”,
“_MACHINE_ID” : “5baeea1b46b14f8a808cb8a6ae19ec7d”,
“MESSAGE” : “ts=2021-06-02T07:41:42.990122Z lvl=debug msg=Request log_id=0TyV~fGl000 service=http method=POST host=XXX:8086 path=/api/v2/write query=“bucket=jjj&org=foookin_paavel” proto=HTTP/2.0 status_code=204 response_size=0 content_length=99 referrer= remote=XXX:36220 user_agent=curl took=82.900ms”,
“__CURSOR” : “s=51eb37556ff24ca6ae461506f3737254;i=2173;b=75840e056e5e40f0876f943cd59866ed;m=3c5247878a6;t=5c3c397009570;x=a92feac53a610dea”,
“__MONOTONIC_TIMESTAMP” : “4145255315622”,
“_CMDLINE” : “/usr/bin/influxd”,
“_GID” : “998”,
“_SYSTEMD_UNIT” : “influxdb.service”,
“_SYSTEMD_INVOCATION_ID” : “03e11acb1df3466c881fbade1b6e17b1”,
“_BOOT_ID” : “75840e056e5e40f0876f943cd59866ed”,
“_UID” : “998”
#precision set to MS
#record can be found
Jun 02 07:47:01 komar influxd[29321]: ts=2021-06-02T07:47:01.299091Z lvl=debug msg=Request log_id=0TyV~fGl000 service=http method=POST host=XXX:8086 path=/api/v2/write query=“bucket=jjj&org=foookin_paavel&precision=ms” proto=HTTP/2.0 status_code=204 response_size=0 content_length=99 referrer= remote=XXX:36270 user_agent=curl took=23.715ms
“_UID” : “998”,
“__REALTIME_TIMESTAMP” : “1622620021299161”,
“__MONOTONIC_TIMESTAMP” : “4145573624591”,
“MESSAGE” : “ts=2021-06-02T07:47:01.299091Z lvl=debug msg=Request log_id=0TyV~fGl000 service=http method=POST host=XXX:8086 path=/api/v2/write query=“bucket=jjj&org=foookin_paavel&precision=ms” proto=HTTP/2.0 status_code=204 response_size=0 content_length=99 referrer= remote=XXX:36270 user_agent=curl took=23.715ms”,
“_GID” : “998”,
“__CURSOR” : “s=51eb37556ff24ca6ae461506f3737254;i=22c0;b=75840e056e5e40f0876f943cd59866ed;m=3c537717b0f;t=5c3c3a9f997d9;x=caab35cdbb64da68”,
“_PID” : “29321”,
“PRIORITY” : “6”,
conan@komar:~$ influx query -o foookin_paavel --skip-verify ‘from(bucket:“jjj”) |> range(start: -24h) |> filter(fn: (r) => r["_measurement"] == “battery_adc” and r.BatUlId == “24xac494d38c” and r.BatSenKey == “24”) |> filter(fn: (r) => r["_field"] == “BatKey”) |> filter(fn: (r) => r["_value"] == 11943) |> sort(columns: ["_time"], desc:true)’ --raw
#group,false,false,true,true,false,false,true,true,true,true,true
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,double,string,string,string,string,string
#default,_result,
,result,table,_start,_stop,_time,_value,BatSenKey,BatUlId,_field,_measurement,host
,0,2021-06-01T08:04:50.775959032Z,2021-06-02T08:04:50.775959032Z,2021-06-02T07:40:16.017Z,11943,24,24xac494d38c,BatKey,battery_adc,komar
also nothing visible in /var/log/messages
#no record written
572  Jun  2 07:41:42 komar influxd[29321]: ts=2021-06-02T07:41:42.990122Z lvl=debug msg=Request log_id=0TyV~fGl000 service=http method=POST host=XXX:8086 path=/api/v2/write query=“bucket=jjj&org=foookin_paavel” proto=HTTP/2.0 status_code=204 response_size=0 content_length=99 referrer= remote=XXX:36220 user_agent=curl took=82.900ms
573  Jun  2 07:42:17 komar influxd[29321]: ts=2021-06-02T07:42:17.039981Z lvl=debug msg=“user find by ID” log_id=0TyV~fGl000 store=new took=0.034ms
574  Jun  2 07:42:17 komar influxd[29321]: ts=2021-06-02T07:42:17.041214Z lvl=debug msg=“org find” log_id=0TyV~fGl000 store=new took=0.048ms
575  Jun  2 07:42:17 komar influxd[29321]: ts=2021-06-02T07:42:17.051980Z lvl=debug msg=“bucket find” log_id=0TyV~fGl000 store=new took=0.124ms
#record ok
847  Jun  2 07:47:01 komar influxd[29321]: ts=2021-06-02T07:47:01.299091Z lvl=debug msg=Request log_id=0TyV~fGl000 service=http method=POST host=XXX:8086 path=/api/v2/write query=“bucket=jjj&org=foookin_paavel&precision=ms” proto=HTTP/2.0 status_code=204 response_size=0 content_length=99 referrer= remote=XXX:36270 user_agent=curl took=23.715ms
848  Jun  2 07:47:05 komar influxd[29321]: ts=2021-06-02T07:47:05.185712Z lvl=debug msg=“user find by ID” log_id=0TyV~fGl000 store=new took=0.034ms
849  Jun  2 07:47:05 komar influxd[29321]: ts=2021-06-02T07:47:05.187727Z lvl=debug msg=“org find” log_id=0TyV~fGl000 store=new took=0.078ms
850  Jun  2 07:47:05 komar influxd[29321]: ts=2021-06-02T07:47:05.203001Z lvl=debug msg=“bucket find” log_id=0TyV~fGl000 store=new took=0.083ms
thank you, pavel
