How do you query specific columns?
Hiya :wave:. I’m using C# client, is it possible to SELECT like SQL and get just account/created_at/from_amount/to_amount and operation_id columns with their values? Cuz I can not do it with Flux :confused:
Like:
SELECT account, created_at, from_amount, operation_id, to_amount FROM mytable
Did you try to build the query using Influx Data Explorer (no coding…just picking items from each list)?
Yeah, I did it with the Influx UI but cant filter/select just the columns I want
Hi @maury,
thanks for using our client.
You can use keep() function.
Regards
Hey @bednar :wave:,
That actually did the work! :clap: Thank you.
Also, can I ask you how can I order the rows by created_at? I have mix up dates and I don’t know how to order them
I’m pushing to influx like this:
What about sort function? - sort() function | Flux 0.x Documentation
