I am trying to change the username used on this forum. I can’t find where this can be done.
Is it possible?
Is it possible?
You should be able to do that from your account preference:
That only allows me to edit my profile picture.
I should have been more specific - I only have the little pencil (edit) next to my profile picture.
can’t tell why… might be due to “trust level”… if you can’t edit it then the next option is to delete and re-create the account
@Giovanni_Luisotto Thank you!
