I am trying to make a request to an HTTPS server with the node.js module, and it isn’t working. The actual influxdb instance is HTTPS (w/ self-signed cert) and accessible, and the query I think runs in module runs perfectly fine (ie returns results) with curl -k. My setup is this:
import { InfluxDB } from 'influx'
const influx = new InfluxDB( {
protocol : "https" ,
host : "my.influxdb.instance" ,
port : "8086" ,
database : "telegraf" ,
username: '...',
password: '...',
options : {
rejectUnauthorized: false ,
and the query, unchanged from a working query with HTTP, is
influx.query(`
select 100.0 - usage_idle as "usage" from cpu
where host = '${name}'
and cpu = 'cpu-total'
(name is in scope). I receive no data and get a GET error; moreover I see no response details in the developer console’s Network panel for the failed requests.
If I copy and paste the encoded request to a terminal with curl -k it runs fine and I get data.
