Dear team,
I’m using InfluxDB to store website ranking (SERP data), I can say it’s alot.
The idea is when you do the search with “keyword research”, we will have a lot of website in the resuls.
We will store first 100 results into SERP.
Here’s the data schema:
schema: [
measurement: 'keyword_daily',
fields: {
domain: Influx.FieldType.STRING,
link: Influx.FieldType.STRING,
title: Influx.FieldType.STRING,
desc: Influx.FieldType.STRING,
keyword: Influx.FieldType.STRING,
position: Influx.FieldType.INTEGER,
keyword_id: Influx.FieldType.INTEGER,
campaign_id: Influx.FieldType.INTEGER,
unique_key: Influx.FieldType.STRING,
tags: []
Here’s the sample data: JSON Editor Online: JSON editor, JSON formatter, query JSON
Curently, I have 10 bot that run frequently to crawl google data, after that, it will save to InfluxDb via InfluxDB-PHP SDK.
The problem: I can see that the RAM usage and the CPU consume is at the top, here’s the graph to say it all.
CPU Usage:
RAM Usage: screenshot-ca.ovh.com-2019.09.26-11_03_45 - Nimbus Capture
I don’t know why/what is the problem.
My installation specs:
- 32Gb RAM 4 core 8 threads
- Centos 7
- InfluxDB 1.7.8
Thank you for your time!
