Help with querying several fields from the same point
I need help with Flux in InfluxDB 2.0.
I need my query to group fields in just one point, when timestamp is the same. In the example below, I would like it to return just one point line with all its fields and not separately. How would the query be? Thank you!
Look at the Flux group() function, specifically I think you can group by device_id although the second table has some odd quoting around the device id that may cause trouble.
