I’m having problems with the restore procedure described in restore data to an existing database.
influx --version
InfluxDB shell version: 1.8.10
I need to restore data from a temporary database efd-1015 to an existing database, but I get the following error:
> SELECT * INTO "efd".autogen.:MEASUREMENT FROM "efd-s1015".autogen./.*/ GROUP BY *
ERR: partial write: field type conflict: input field "position" on measurement "lsst.sal.ATPneumatics.logevent_m1VentsPosition" is type float, already exists as type integer dropped=2
Note that the field position is an integer in both databases, and that’s why the error message doesn’t make sense to me.
> SHOW FIELD KEYS on "efd-s1015" FROM "lsst.sal.ATPneumatics.logevent_m1VentsPosition"
fieldKey fieldType
position integer
priority integer
private_efdStamp float
private_identity string
private_kafkaStamp float
private_origin integer
private_rcvStamp float
private_revCode string
private_seqNum integer
private_sndStamp float
and
> SHOW FIELD KEYS on "efd" FROM "lsst.sal.ATPneumatics.logevent_m1VentsPosition"
fieldKey fieldType
position integer
priority integer
private_host integer
Trying to investigate the error I decided to restore the data to a new (empty) database:
> CREATE DATABASE test
> SELECT * INTO "test"."autogen".:MEASUREMENT FROM "efd-s1015".autogen./.*/ GROUP BY * limit 1
time written
0 881
For my surprise the query above is not preserving the original data type for the field position in the lsst.sal.ATPneumatics.logevent_m1VentsPosition measurement, while it seems to be preserving the data types for the other fields.
> SHOW FIELD KEYS on "test" from "lsst.sal.ATPneumatics.logevent_m1VentsPosition"
fieldKey fieldType
position float
priority integer
The fact that the field position is created with type float is in agreement with the initial error. However, If I specify the measurement name in the query the original data type is preserved:
> DROP DATABASE test
> SELECT * INTO "test"."autogen"."lsst.sal.ATPneumatics.logevent_m1VentsPosition" FROM "efd-s1015"."autogen"."lsst.sal.ATPneumatics.logevent_m1VentsPosition" GROUP BY * limit 1
time written
0 1
fieldKey fieldType
position integer
priority integer
I’m wondering if there’s a bug with the query that iterates over all the measurements, because the field positon exists on different measurements as integer or float - and the underlying code might be assuming the data type of the last occurrence of the field position or something like that.
> SELECT position FROM "efd-s1015"."autogen"./.*/ GROUP BY * limit 1
time position
1655221053999000000 2
time position
1655480976542000000 -0.0008915923758653858
time position
1655476430492000000 0
time position
1655480976484000000 0.09910850419126974
fieldKey fieldType
position integer
> SHOW FIELD KEYS on "efd-s1015" FROM "lsst.sal.MTRotator.logevent_target"
fieldKey fieldType
position float
