Need urgent help on deadman alter timings.
Below script is working fine, but am getting alert after 5 mins, where as i should trigger 4th Min.
Deadman takes minimum 5 min before it execute custom alert script. And it stop working if i reduce deadman timing to 2 mins.
var STRDOWN = 'FAILED'
var data = stream
|from()
.measurement('smoketest')
.groupby('region', 'server', 'type')
|window()
.period(1m)
.every(15s)
.align()
|httpOut('smoketest_out')
|where(lambda: isPresent("status_str"))
|last('status_str')
.as('status_str')
|log()
var apac = data
|where(lambda: "region" == 'APAC')
|eval(lambda: "region")
.as('region')
.keep()
|httpOut('smoketest_APAC_OUT')
var deadman_out = data
|log()
|deadman(0.0, 3m)
.critReset(lambda: "emitted" > 1)
.log('/tmp/smoketest.log')
.exec('CUSTOM ALERT SCRIPT') **## working fine, but alert coming after 5mins, expected 3 mins**
.stateChangesOnly()
.NoRecoveries()
|log()
