We’re running TIG stack and noticed CPU has been unexpectedly high since March this year.
There were no changes I know of which may have impacted this. Is there a way we can find out which query may be running too frequently?
Hi there, see attached.
@Anaisdg Also see debug info attached.influxdata.tar.gz (2.6 MB)
Hi @Anaisdg - have you had a moment to check the logs? Are there any other diagnostics we can run?
I would provide you system info but I’m not sure if matters since it was running OK with the same number of hosts (and a bunch were disabled to check if it’s related to this high CPU usage.
