I’m trying to get a line chart of, kind of “query per seconds”, or “per x seconds”.
My counter is saved every 15 seconds.
Sometimes, I may have a whole in the datas, like no datas for 30 minutes.
When it append, the line chart has a huge point which I don’t know how to handle.
There is screen 1 with the counter datas, and screen 2 with the difference. What you see is missing datas, when data is there again, the first new point is like at 2000, then normal again.
I don’t even know if there is something wrong, but can you check the request please ?
Hello @Johndodev,
can you explain in a little more detail what’s happening?
I can also replicate a similar spike, but the difference is still being calculated as expected for example:
import "array"
data = array.from(rows: [
{_time: time(v: "2024-03-20T00:00:00Z"), _field: "temperature", _value: 20.0},
{_time: time(v: "2024-03-20T01:00:00Z"), _field: "temperature", _value: 21.0},
{_time: time(v: "2024-03-20T02:00:00Z"), _field: "temperature", _value: 22.0},
{_time: time(v: "2024-03-20T03:00:00Z"), _field: "temperature", _value: 23.0},
// 4-hour gap here
{_time: time(v: "2024-03-20T07:00:00Z"), _field: "temperature", _value: 27.0},
{_time: time(v: "2024-03-20T08:00:00Z"), _field: "temperature", _value: 28.0},
{_time: time(v: "2024-03-20T09:00:00Z"), _field: "temperature", _value: 29.0},
{_time: time(v: "2024-03-20T10:00:00Z"), _field: "temperature", _value: 30.0},
{_time: time(v: "2024-03-20T11:00:00Z"), _field: "temperature", _value: 31.0},
{_time: time(v: "2024-03-20T12:00:00Z"), _field: "temperature", _value: 32.0}
data
|> range(start: time(v: "2024-03-20T00:00:00Z"), stop: time(v: "2024-03-20T12:00:00Z"))
|> yield(name: "before difference")
|> difference(nonNegative: false, columns: ["_value"])
|> yield(name: "after difference")
|> aggregateWindow(every: 2h, fn: mean, createEmpty: false)
|> yield(name: "after agg")
Where before difference is:
20
21
22
23
27
28
29
30
31
the after difference is:
1
1
1
4
1
1
1
1
1
And the aggregate window after results are
1
1
4
1
As we can see we still get a spike but this isn’t due to the time gap. Its just that the difference is higher there and that’s being reflected accurately in the subsequent calculations.
I recommend using multiple yield statements like I did to help dive into the data to see what’s the cause of your unexpected output and then maybe handle that special case iwth some additional flux.
yes it is working as expected, I was pretty sure it was a logic problem, on my side.
I’ve dived more into the doc, tryied some stuff with “fill” and “createEmpty”, then I found the derivative function, which is exaclty what I needed ! Which was, “do not calculate the difference when n-1 data is null” (and do not use the previous non null value).
Thanks !
