The formual of CQ is : “cms.sip.active.cps” = last(“cms.sip.active.cps”) + 2 * mean(“cms.session.sip.active”) ; increment the cms.sip.active.cps with last value of it and the value of cms.session.sip.active;
thanks in advance.
PART I Test Enviroment
Test Enviroment: CentOS 7
Influxdb version: version=1.5.4 branch=1.5 commit=4e4e00bc5ab85a3ff5e988c91020cf0399a87026
Startup logging:
ts=2019-05-09T15:44:21.943743Z lvl=info msg=“InfluxDB starting” log_id=0FJK6sil000 version=1.5.4 branch=1.5 commit=4e4e00bc5ab85a3ff5e988c91020cf0399a87026
ts=2019-05-09T15:44:21.943829Z lvl=info msg=“Go runtime” log_id=0FJK6sil000 version=go1.9.2 maxprocs=40
ts=2019-05-09T15:44:21.944736Z lvl=info msg=“Using data dir” log_id=0FJK6sil000 service=store path=/var/lib/xms/metrics/influx/data
ts=2019-05-09T15:44:21.944790Z lvl=info msg=“Open store (start)” log_id=0FJK6sil000 service=store trace_id=0FJK6sj0000 op_name=tsdb_open op_event=start
ts=2019-05-09T15:44:24.640535Z lvl=info msg=“Starting continuous query service” log_id=0FJK6sil000 service=continuous_querier
show continuous queries
name query
cqd CREATE CONTINUOUS QUERY cqd ON meters BEGIN SELECT last(“cms.sip.active.cps”) + 2 * mean(“cms.session.sip.active”) AS “cms.sip.active.cps” INTO meters.cms FROM meters.cms GROUP BY time(1m) END
name query
PART II log about influxdb continuous query exection
ts=2019-05-09T15:45:00.652339Z lvl=info msg=“Continuous query execution (start)” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJK9Ew0000 op_name=continuous_querier_execute op_event=start
ts=2019-05-09T15:45:00.652395Z lvl=info msg=“Executing continuous query” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJK9Ew0000 op_name=continuous_querier_execute name=cqd db_instance=meters start=2019-05-09T15:44:00.000000Z end=2019-05-09T15:45:00.000000Z
ts=2019-05-09T15:45:00.652584Z lvl=info msg=“Executing query” log_id=0FJK6sil000 service=query query=“SELECT last("cms.sip.active.cps") + 2 * mean("cms.session.sip.active") AS "cms.sip.active.cps" INTO meters.cms FROM meters.cms WHERE time >= ‘2019-05-09T15:44:00Z’ AND time < ‘2019-05-09T15:45:00Z’ GROUP BY time(1m)”
ts=2019-05-09T15:45:00.653914Z lvl=info msg=“Finished continuous query” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJK9Ew0000 op_name=continuous_querier_execute name=cqd db_instance=meters written=0 start=2019-05-09T15:44:00.000000Z end=2019-05-09T15:45:00.000000Z duration=1ms
ts=2019-05-09T15:45:00.675613Z lvl=info msg=“Continuous query execution (end)” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJK9Ew0000 op_name=continuous_querier_execute op_event=end op_elapsed=23.284ms
ts=2019-05-09T15:46:00.694844Z lvl=info msg=“Continuous query execution (start)” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKCuTW000 op_name=continuous_querier_execute op_event=start
ts=2019-05-09T15:46:00.694890Z lvl=info msg=“Executing continuous query” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKCuTW000 op_name=continuous_querier_execute name=cqd db_instance=meters start=2019-05-09T15:45:00.000000Z end=2019-05-09T15:46:00.000000Z
ts=2019-05-09T15:46:00.695079Z lvl=info msg=“Executing query” log_id=0FJK6sil000 service=query query=“SELECT last("cms.sip.active.cps") + 2 * mean("cms.session.sip.active") AS "cms.sip.active.cps" INTO meters.cxm FROM meters.cms WHERE time >= ‘2019-05-09T15:45:00Z’ AND time < ‘2019-05-09T15:46:00Z’ GROUP BY time(1m)”
ts=2019-05-09T15:46:00.696064Z lvl=info msg=“Finished continuous query” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKCuTW000 op_name=continuous_querier_execute name=cqd db_instance=meters written=0 start=2019-05-09T15:45:00.000000Z end=2019-05-09T15:46:00.000000Z duration=1ms
ts=2019-05-09T15:46:00.707184Z lvl=info msg=“Continuous query execution (end)” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKCuTW000 op_name=continuous_querier_execute op_event=end op_elapsed=12.372ms
ts=2019-05-09T15:47:00.726620Z lvl=info msg=“Continuous query execution (start)” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKGZyW000 op_name=continuous_querier_execute op_event=start
ts=2019-05-09T15:47:00.726665Z lvl=info msg=“Executing continuous query” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKGZyW000 op_name=continuous_querier_execute name=cqd db_instance=meters start=2019-05-09T15:46:00.000000Z end=2019-05-09T15:47:00.000000Z
ts=2019-05-09T15:47:00.726838Z lvl=info msg=“Executing query” log_id=0FJK6sil000 service=query query=“SELECT last("cms.sip.active.cps") + 2 * mean("cms.session.sip.active") AS "cms.sip.active.cps" INTO meters.cms FROM meters.cms WHERE time >= ‘2019-05-09T15:46:00Z’ AND time < ‘2019-05-09T15:47:00Z’ GROUP BY time(1m)”
ts=2019-05-09T15:47:00.727822Z lvl=info msg=“Finished continuous query” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKGZyW000 op_name=continuous_querier_execute name=cqd db_instance=meters written=0 start=2019-05-09T15:46:00.000000Z end=2019-05-09T15:47:00.000000Z duration=1ms
ts=2019-05-09T15:47:00.738694Z lvl=info msg=“Continuous query execution (end)” log_id=0FJK6sil000 service=continuous_querier trace_id=0FJKGZyW000 op_name=continuous_querier_execute op_event=end op_elapsed=12.078ms
PART III output in database – NO UPDATE AT ALL
select last(“cms.sip.active.cps”) from cms
time last
1557354900000000000 148.83050847457628
time last
time last
time last
time last
