Handling empty result sets
I’m using the Influx Python3 library to query an InfluxDB (2.6.1). The query I’m working on at the moment will return an empty set of results at times and this is expected.
How can I check a set of results to see if they are empty or not before processing them?
The query:
    open_query = ' from(bucket:"' + influx_client_bucket + '")\
        |> range(start: -1d)\
        |> filter(fn: (r) => r["_measurement"] == "a")\
        |> last()\
        |> filter(fn: (r) => r["_value"] == 1)\
        |> drop(columns: ["_start", "_stop", "_time", "_field", "_measurement", "_value"])'
    open_query_result = query_api.query(org=influx_client_org, query=open_query)
As per this: Empty condition for Result Set in Python Client
The problem is even though the query returns 0 results the length of the result set is not 0:
print(len(open_query_result))
1
for table in open_query_result:
...     for record in table.records:
...             print((record.values.get("SOMETHINGHERE")))
None
What is the current method for checking that a query has some results?
Hoping someone might be able to give me a little direction here…
Hello @olliecampbell,
You could append your query
import "array"
alternative = array.from(rows: [{v: 0}])
        |> range(start: -1d)\
        |> last()\
check = (open_query |> count()  |> findRecord( fn: (key) => true, idx: 0) )._value
if check > 0 then
open_query |> yield() else
alternative |> yield()
Here’s a dummy example;
import "array"
alternative = array.from(rows: [{_value: 0}])
 open_query = array.from(rows: [{_value: 5}])
if check > 0 then
Hope that helps
Perfect, thank you. My SQL statements aren’t up to scratch, but that should help nicely.
I did get better result with “exists” on check than with >0. No time to dig more but if it can help anybody.
if exists check then
  open_query |> group () |> yield()
  else
