Is there a way to group by all but one tag. You can group by a regex but It doesn’t look like go lang supports negative look ahead regexes. If it’s a field we can use the !~ operator to do a negative match, but I don’t see anyway to do that on a group by statement.
Basically I am looking to do something like
SELECT sum("m1") FROM "metric" WHERE time > now() - 24h GROUP BY time(10s), !~/bar/
So sum the metric and group by all the tags except for the bar tag
