Grafana crashes when querying too much data
For some reason when I try to query two full days worth of data, InfluxDB/Grafana crashes. I get the following error message in chrome:
Has anyone else ran into this problem? I have tried increasing Chrome’s cache size but it doesn’t seem to fix the problem.
Thanks to all of those who reply in advance.
Hi @kyled, are you able to run the same query in the CLI without problems?
@Sonia_Gupta Yes it works fine. I am thinking it might be a problem with chrome itself… Not sure what it could be though, which is why I posted to see if anyone else might have ran into the same problem.
Have you tried to enable logging in Chrome to see what might be causing the crash?
