Hi.
I want to get max temperature per day. I use aggregatewindow but i cannot get rid of some columns in output table.
Query:
from(bucket: "openhab/autogen")
|> range($range)
|> filter(fn: (r) => r._measurement == "Vitocal_Aussentemperatur" and (r._field == "value"))
|> aggregateWindow(every: 1d, fn: max)
|> keep(columns: ["_time", "_value"])
|> rename(columns: {_value: "Max"})
Result:
I only want the “Max” column. How to achieve this?
best regards
