I want to get stage name per build and parent folder wise in influxdb and show on grafana dashboard.
I’m using InfluxDB to collect other jenkins build metrics but stage name is not built-in supported hence I’ve created customData for stage name, hence through whichever stage build will parse, it collects the stage name and send to influxdb and I get data as below.
time build_number build_time project_name project_name_1 project_path project_path_1 stage1 stage2 stage3 stage4 stage5 stage6 stage7 stage8
1588084985624000000 3 19824 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Checkout SCM Publish to InfluxDB petclinic
1588085162281000000 4 38600 testPipeline testPipeline petclinic/testPipeline petclinic/testPipeline Get application version Send Parameters To Spinnaker Build Publish to InfluxDB petclinic
1588085231934000000 4 38785 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Get application version Send Parameters To Spinnaker Build Publish to InfluxDB petclinic
1588085356705000000 5 3616 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Checkout SCM Publish to InfluxDB petclinic
1588085797787000000 7 41916 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Checkout SCM Get application version Publish to InfluxDB petclinic
1588086095058000000 10 81730 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Checkout SCM Get application version Publish to InfluxDB TestFolder
1588087475800000000 11 43199 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Checkout SCM Get application version Publish to InfluxDB TestFolder
1588087564498000000 12 18748 TestPetclinic TestPetclinic TestFolder/TestPetclinic TestFolder/TestPetclinic Checkout SCM Get application version Publish to InfluxDB TestFolder
From this I can easily get data per build wise(job wise) but struggling with getting data folder wise.
Hence I’m also parsing hard-coded value in each job inside folder, last column in above table data ex.
Folder Name: abc > Job 1 contains custom data field key: stage8 value: "abc"
Folder Name: abc > Job 2 contains custom data field key: stage8 value: "abc"
Folder Name: xyz > Job 1 contains custom data field key: stage8 value: "xyz"
Folder Name: xyz > Job 2 contains custom data field key: stage8 value: "xyz"
Through which I get extra stage8 with 2 different values as per folder name.
Next in grafana, I’m trying to create the query, to get expected data like
stage8 Checkout SCM Get application version Send Parameters To Spinnaker Build Unit Test & Publish Report Jacoco
petclinic 14 15 8 7 4 3
TestFolder 11 12 9 8 8 8
But with this query
SELECT count("stage1") as "Checkout SCM", count("stage2") as "Get application version" , count("stage3") as "Send Parameters To Spinnaker", count("stage4") as "Build", count("stage5") as "Unit Test & Publish Report", count("stage6") as "Jacoco" FROM "jenkins_custom_data" GROUP BY "stage8"
23 27 17 15 12 11
And when I run group by query for stage8
SELECT count("stage1") as "Checkout SCM", count("stage2") as "Get application version" , count("stage3") as "Send Parameters To Spinnaker", count("stage4") as "Build", count("stage5") as "Unit Test & Publish Report", count("stage6") as "Jacoco", stage8 FROM "jenkins_custom_data" group by stage8
Then I get this error
ERR: mixing aggregate and non-aggregate queries is not supported
Now, I’ve got this query individually
select count("stage1") as "Checkout SCM", count("stage2") as "Get application version" , count("stage3") as "Send Parameters To Spinnaker", count("stage4") as "Build", count("stage5") as "Unit Test & Publish Report", count("stage6") as "Jacoco" from jenkins_custom_data where stage8 = 'petclinic'
select count("stage1") as "Checkout SCM", count("stage2") as "Get application version" , count("stage3") as "Send Parameters To Spinnaker", count("stage4") as "Build", count("stage5") as "Unit Test & Publish Report", count("stage6") as "Jacoco" from jenkins_custom_data where stage8 = 'TestFolder'
And able to get data but when join these 2 query in table then cannot say that which result is from which query because again raw name cannot display because of mix aggregation query.
Please advise to resolve this.
