Get latest N records from InfluxDB table
Is it possible to query latest N records from a table with a single query?
Now I am using two queries for getting the latest N records as given below. Is this the right way?
1. SELECT LAST(*) FROM "h2o_feet"
2. SELECT LAST(*) FROM "h2o_feet" where time < t1
where t1 is the timestamp of record obtained from Step1. Step2 will be executed N-1 times with the timestamp obtained from previous step
SELECT * FROM “h20_feet” ORDER BY time DESC LIMIT N
Sounds inefficient, but then again several back-end data stores are also
inefficient when you ask for “ORDER BY time DESC”, so try both and see which
works best for you.
Antony.
