Get duration of certain field value InfluxDB
Hello!
I have this on my database:
time running
2022-09-16 09:00:00 False
2022-09-16 09:05:00 False
2022-09-16 09:10:00 True
2022-09-16 09:40:00 True
2022-09-16 10:00:00 False
2022-09-16 12:00:00 True
2022-09-16 12:10:00 False
I want to get this result:
Duration True: 1h
Duration False: 2h 10 min
1h = 30 min (09:10-09:40) + 20 min (09:40-10:00) + 10 min (12:00-12:10)
2h 10 min = 5 min (09:00-09:05) + 5 min (09:05-09:10) + 120 min (10:00-12:00)
It doesn’t matter if I use Flux or InfluxQL.
I have this csv to extract the number of events of True and False, but I am more interested in the duration of each value:
import "csv"
csvData = "#group,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE,FALSE
#datatype,string,long,dateTime:RFC3339,dateTime:RFC3339,dateTime:RFC3339,string,string,string,string,string,string,string,string,string,string,string,string,string
#default,_result,,,,,,,,,,,,,,,,,
,result,table,_start,_stop,_time,_value,_field,_measurement,dest_ip,dest_port,event_type,flow_id,host,in_iface,path,proto,src_ip,src_port
,,0,2022-09-16T09:00:00.00000000Z,2022-09-16T09:00:00.00000000Z,2022-09-16T09:00:00.00000000Z,False,PLC,suricata-alerts,192.168.0.14,80,alert,1437107460025591,opnsense.home.arpa,re1_vlan742^,/var/log/suricata/eve.json,TCP,111.111.111.111,36766
,,0,2022-09-16T09:05:00.00000000Z,2022-09-16T09:05:00.00000000Z,2022-09-16T09:05:00.00000000Z,False,PLC,suricata-alerts,192.168.0.14,80,alert,2166347159271520,opnsense.home.arpa,re1_vlan742^,/var/log/suricata/eve.json,TCP,222.222.222.222,34387
,,0,2022-09-16T09:10:00.00000000Z,2022-09-16T09:10:00.00000000Z,2022-09-16T09:10:00.00000000Z,True,PLC,suricata-alerts,192.168.0.14,80,alert,321927463147576,opnsense.home.arpa,re1_vlan742^,/var/log/suricata/eve.json,TCP,110.110.110.110,11751
,,0,2022-09-16T09:40:00.00000000Z,2022-09-16T09:40:00.00000000Z,2022-09-16T09:40:00.00000000Z,True,PLC,suricata-alerts,192.168.0.14,80,alert,333555236012237,opnsense.home.arpa,re1_vlan742^,/var/log/suricata/eve.json,TCP,100.100.100.100,13488
,,0,2022-09-16T10:00:00.00000000Z,2022-09-16T10:00:00.00000000Z,2022-09-16T10:00:00.00000000Z,False,PLC,suricata-alerts,192.168.0.14,80,alert,334429991280534,opnsense.home.arpa,re1_vlan742^,/var/log/suricata/eve.json,TCP,180.180.180.180,53958
,,0,2022-09-16T12:00:00.00000000Z,2022-09-16T12:00:00.00000000Z,2022-09-16T12:00:00.00000000Z,True,PLC,suricata-alerts,192.168.0.14,80,alert,33606186887911,opnsense.home.arpa,re1_vlan742^,/var/log/suricata/eve.json,TCP,180.180.180.180,45018
,,0,2022-09-16T12:10:00.00000000Z,2022-09-16T12:10:00.00000000Z,2022-09-16T12:10:00.00000000Z,False,PLC,suricata-alerts,123.123.123.123,80,alert,1554565580150037,opnsense.home.arpa,re0,/var/log/suricata/eve.json,TCP,150.150.150.150,511"
csv.from(csv: csvData)
|> group(columns: ["_value"])|> set(key: "Count", value: "my_Count")|> count(column: "Count")```
Can someune help me with the query?
Thank you!
Hello @mmmmgggg,
Yes! I’m so sorry for the delay. Sometimes questions fall through the cracks. Next time you dont hear back, please tag me.
Thank you for providing sample input data you rock!
You would do:
import "csv"
|> stateDuration(unit: 1m, fn: (r) => true)
Using stateDuration:
This doc does a good example of highlighting other like functions too that are worth knowing about.
