Hello!
I have a query like this:
getSummaryMetrics = (aggregateFunction, field) => from(bucket: "blabla")
|> range(start: 0)
|> filter(fn: (r) =>
r["_field"] == field and
|> aggregateFunction()
|> group(columns: ["..."])
|> pivot(rowKey:["...."], columnKey: ["_field"], valueColumn: "_value")
getSummaryMetrics(aggregateFunction: min, field: "min")
getSummaryMetrics(aggregateFunction: max, field: "max")
The bottom line is that I filter by field and select aggregation for this. I think this is a little dirty solution… Is there any solution for create condition “inside” query for get necessary aggregation function? Something like that:
|> if r._field == "max" then max()
Perhaps need to create Map with structure fieldName : aggregation function
I also have a problem that when there is a need to call a function with parameters:
getSummaryMetricsQuantile = (quantileFunction, field) => from(bucket: "blabla")
|> range(start: 0)
|> filter(fn: (r) =>
|> quantileFunction()
getSummaryMetricsQuantile(quantileFunction: quantile(q: 0.5), field: "percentiles50")
Unfortunately cannot call quantileFunction()
with pass quantile(q: 0.5)
Thanks in advance for any help and tips!
