I’m currently trying to solve a problem with Flux and SQL. I have a SQL Database, where I’m filtering for a specific criteria, which corresponds to multiple Sensors with a SensorID each and one or many portnumber(s). The data of the sensors is written to the InfluxDB via a Telegraf Client and identified by the SensorID and the portnumber. I already have the call to the SQL DB in Flux. Imagine the following Table as a result:
| Port | SensorID |
| 37 | 31011 |
| 38 | 31011 |
| 39 | 44522 |
| 40 | 44522 |
Now, I normally would do something like this:
from(bucket: "Sensors")
|> filter(fn: (r) => r["_measurement"] == "SomeValue")
|> filter(fn: (r) => r["SensorID"] == "31011")
|> filter(fn: (r) => r["_field"] == "37")
|> yield(name: "mean")
…but instead of the fixed values for the SensorID and the _field (portnumber), I would like to iterate over each row of the first table and insert the values for the SensorID and _field (portnumber) dynamically, so I can see all datastreams (in this case four) in the resulting table. Is there an easy way to achieve this?
