Formatting date with leading zeros
Hello
I need your help to transform my day, month, year fields into a date in yyyy-mm-dd format
At the moment, using the processor.template plugin, I get a date like: 2021-5-9 instead of 2021-05-09.
Would you know how to fix this problem?
Thanks in advance
You can use the date processor for this.
It allows you to specify the desired date format and should keep leading zeroes.
