Flux range can't find datapoint with _time value within the specified range
I have datapoints with various _time values. One of them has a _time value of 2023-04-15 11:07:12 GMT+2
With a range of
range(
  start: 2023-04-15T10:00:00.000+02:00,
  stop:  2023-04-16T13:00:00.000+02:00
I can find it (notice that the stop timestamp is one day later). I can locate the datapoint, and in its _start value it says 2023-04-15 10:00:00 GMT+2, and in its _stop value 2023-04-16 01:00:00 GMT+2
A range of
range(
  stop:  2023-04-15T13:00:00.000+02:00
doesn’t. The _stop value of all datapoints is 2023-04-15 01:00:00 GMT+2. It finds datapoints with _time values from 2023-04-15 10:07:14 GMT+2 to 2023-04-15 12:57:14 GMT+2, but the datapoint I am looking for is not there.
Absolutely no clue what’s going on there. The query looks very basic to me. I just filter by _measurement and tags, nothing else. There is no aggregation of some sorts going on in my query that might omit the datapoint.
  1. Why is _stop showing something completely different from my range query?
  2. What could cause the datapoint to go missing
so, start and stop values will be always the ones you set as _start and _stop.
the actual timestamp is the _time value.
and _stop value is evaluated as “less than” so if your _time value is as an example: 2023-04-15T13:00:00.000+02:00, it won’t show up. with this range:
range(
because is equal to the _stop value, not less.
I am not sure if this was your issue, but hope It helps.
also, there is a bug on which the time is shown as 12hrs format, so :2023-04-15 01:00:00 GMT+2 is indeed 2023-04-15T13:00:00.000+02:00 (I’ve noticed that on the Influx Data Explorer Interface table view)
Thanks, I already noticed this on _start and _stop in the ui, but your remark made me realize this might be the case for the displayed _time value as well. Turns out the timestamp of my datapoint is not 2023-04-15 11:07:12 GMT+2, but 2023-04-15 23:07:12 GMT+2…
