I’ve a query that returns the results of collected metrics of each devices in field.
I just want to give information to the end user about numeric placement on given time arrange.
There may be a better or “canonical” way to approach this, but I believe the following would accomplish what you need:
from(bucket: "db/autogen")
|> range(start: -24h)
// Create a new column for row Id with an initial value of 1
|> map(fn: (r) => ({r with rowId: 1}))
// Taking the cumulative sum gives sequential values 1,2,3,4 et...
|> cumulativeSum(columns: ["rowId"])
