I put my running data into a influxdb2 and it has fields like: heartRate, distance etc. and a tag runName which is unique for every run. What I want as a result is what is the furthest distance I was able to run in 12 minutes, where the stddev of HR was below 5 for each run. (That is a metric that can be calculated to VO2Max).
The first three queries work as expected, but then I get a bit lost. First of all: Do I really need to make that three queries, or is there a smart way to re-use the heartRate window to yield avg and stddev at the same time?
bucket1 = from(bucket: "Running")
|> filter(fn: (r) => r["_measurement"] == "FitnessPoint")
|> filter(fn: (r) => r["_field"] == "heartRate")
|> window(every: 30s, period: 12m)
|> mean()
|> duplicate(column: "_stop", as: "_time")
|> window(every: inf)
|> yield(name: "hrMean")
bucket2 = from(bucket: "Running")
|> stddev()
|> window(every: inf)
|> yield(name: "hrStdDev")
bucket3 = from(bucket: "Running")
|> filter(fn: (r) => r["_field"] == "distance")
|> spread()
|> window(every: inf)
|> yield(name: "cooperDistance")
Then I try to join those three tables into one table and return the biggest distance where my stddev in HR was below 5, but somehow the data explorer seems to completly ignore everything below the first three results. Am I doing something wrong?
j1 = join(
tables: {t1: bucket1, t2:bucket2},
on: ["_time", "type", "runName"]
j2 = join(tables: {t1: j1, t2:bucket3}, on: ["_time", "type", "runName"])
|> filter(fn: (r) => r["hrStdDev"] <= 5)
|> max(column: "cooperDistance")
Update: I got it almost working, but I encounter two problems. The second merge does not like it when I join on type and runName, although I can see them in the sub results, so this works:
j1 = join(
tables: {hrMean: bucket1, hrStdDev:bucket2},
on: ["_time", "_measurement", "_start", "_stop", "_field", "type", "runName"]
// |> yield(name:"SubMerge")
j2 = join(tables: {t1: j1, t2:bucket3}, on: ["_time","_start", "_stop"])
|> filter(fn: (r) => r["_value_hrStdDev"] <=5)
|> duplicate(column: "_value", as: "_value_distance")
|> max()
|> yield(name:"Result")
The second problem is that when I try to drop some columns the InfluxDB process load increases to 100% and I don’t get any data back.
I really appreciate any help I can get here.
