How can I understand that alert in the flapping state? Should there be any signs in ‘kapacitor list’ or ‘kapacitor show’? Because I can’t find any mentions about it even in debug log…
There are no logs about an alert entering or leaving the flapping state. Could you file an issue on github requesting that feature so we can track it? Thanks
I mean is there a dedicated status (just like OK, CRITICAL, etc…) which indicates that “flapping state” has been triggered for the monitored data, or does Kapacitor simply stop sending alerts until that data leaves “flapping state” ?
Ok, I think I just got my answer … from the field.
Flapping state came into play without notification of any sort, then the alerts were simply not triggered anymore, not even a trace in kapacitor log to keep track of things.
But this is not the most annoying: alert state never got reset to OK when measurement data went back to a normal level!
I’m deactivating flapping detection for now.
Is there some specific instruction to add in a TICK script when using flapping detection?
I succeeded in getting into the flapping state but didn’t succeed to get out again.
if you remove the flapping part from your tick script flapping won’t occur anymore
but I guess you already found out
