I am not an expert of InfluxDB but up to now I was able to get what I want.
Now I am stuck ![]()
We monitor the level of our water tank with an ultrasonic sensor. The following diagram shows the water consumption and the refill as an 24h example. The according query is:
SELECT min("value") AS "min_value" FROM "homeassistant"."autogen"."l" WHERE time > :dashboardTime: AND time < :upperDashboardTime: AND "entity_id"='water_tank_volume_2' GROUP BY time(1m) FILL(null)
In order to calculate the water consumption I used the transformation NON_NEGATIVE_DIFFERENCE in the query statement:
SELECT NON_NEGATIVE_DIFFERENCE("min_value") as "delta" FROM (SELECT -min("value") AS "min_value" FROM "homeassistant"."autogen"."l" WHERE time > :dashboardTime: AND time < :upperDashboardTime: AND "entity_id"='water_tank_volume_2' GROUP BY time(1m) FILL(null))
The result looks as expected.
If I like to summarise now the water consumption over a given time period (for instance per day) I only can get the total sum of the entire period and GROUP BY time(1d) doesn’t work:
SELECT sum("delta") as "used" FROM (SELECT NON_NEGATIVE_DIFFERENCE("min_value") as "delta" FROM (SELECT -min("value") AS "min_value" FROM "homeassistant"."autogen"."l" WHERE time > :dashboardTime: AND time < :upperDashboardTime: AND "entity_id"='water_tank_volume_2' GROUP BY time(1m) FILL(null)))
Where is my mistake ?
