I’m stumped. I’m trying to get a TICKscript to determine the rate of errors, but the result of the division operator (/) is always zero.
I’m following the example elsewhere in this community, and have this code (full script at the bottom of this post):
|eval(lambda: "totalErrors.count" / "totals.count")
.as('rate')
|alert()
.message('Count: {{ index .Fields "totals.count" }}; Errors: {{ index .Fields "totalErrors.count" }} Rate: {{ index .Fields "rate" }} Rate2: {{ index .Fields "rate2"}}')
If I feed it a bunch of data, including good and bad values, I get a message in the logs like this:
2017/09/13 08:10:28 D! CRITICAL alert triggered id: msg:Count: 32; Errors: 24 Rate: 0 Rate2: 0 data:&{api_detail map[] [time rate rate2 totalErrors.count totals.count] [[2017-09-13 13:10:11.781652695 +0000 UTC 0 0 24 32]]}
Notice: Count: 32; Errors: 24 Rate: 0 Rate2: 0
How can that be? What am I missing?
I’ve substituted in the actual values and gotten zero:
eval(lambda: 32 / 24).as('rate')
I’ve multiplied by 100 (thinking maybe it’s integer rounding to zero) but got no happiness with either of these:
eval(lambda: ("totalErrors.count" / "totals.count") * 100 )
eval(lambda: ("totalErrors.count" * 100) / ("totals.count" * 100) )
However, I’ve plugged in addition, subtraction and multiplication and all of those work, producing the expected result.
Any ideas what’s up? I’m puzzled.
var data = stream
|from()
.measurement('api_detail')
|window()
.period(20s)
.every(5s)
|log().prefix('initial stream: ').level('DEBUG')
var totalRecords = data
|count('duration')
|log().prefix('totalRecords: ').level('DEBUG')
var totalErrors = data
|where(lambda: "tr-error" == 'true')
|log().prefix('totalErrors (pre-count): ').level('DEBUG')
|count('duration')
|log().prefix('totalErrors (post-count): ').level('DEBUG')
totalErrors
|log().prefix('pre-join: ').level('DEBUG')
|join(totalRecords)
.fill(0)
.as('totalErrors','totals')
.as('rate')
.keep()
|eval(lambda: 12 / 16 )
.as('rate2')
.keep()
|log().prefix('pre-alert: ').level('DEBUG')
|alert()
.id('{{ index .Tags "api"}}')
.crit(lambda: TRUE)
// Whenever we get an alert write it to a file.
.log('/tmp/alerts.log')
