Hello
I use the inputs.http plugin to recover data in json format as below :
[[inputs.http]]
urls = [
"https://www.mon_url.fr:4848/monitoring/domain/instance-production-1/applications/DistributeurWS/server/DistributeurWSService.json",
"https://www.mon_url.fr:4848/monitoring/domain/instance-production-2/applications/DistributeurWS/server/DistributeurWSService.json",
"https://www.mon_url.fr:4848/monitoring/domain/instance-production-1/applications/DistributeurWS/server/EspeceWSService.json",
"https://www.mon_url.fr:4848/monitoring/domain/instance-production-2/applications/DistributeurWS/server/EspeceWSService.json",
"https://www.mon_url.fr:4848/monitoring/domain/instance-recette-1/applications/DistributeurWS/server/DistributeurWSService.json",
"https://www.mon_url.fr:4848/monitoring/domain/instance-recette-1/applications/DistributeurWS/server/EspeceWSService.json",
data_format = "json
method = "GET"
fieldpass = [
"extraProperties_entity_requestcount_count",
"extraProperties_entity_errorcount_count"
I retrieve the url of the data stream in the url tag. I’ve been trying for some time to decompose the url into two other tags: one containing the instance name (e.g. instance-production-1) and the other containing the service name (e.g. EspeceWSService).
I use the processors.regex plugin to parse the url as below :
[[processors.regex]]
order = 1
[[processors.regex.tags]]
key = "url"
pattern = "^https?\:\/\/([A-Za-z0-9\-\_\.\:]*\/)*(instance-[A-Za-z0-9\-]*)([A-Za-z0-9\-\_\.\:]*\/)*([A-Za-z\-]*.json)$"
replacement = "${2}".
result_key = "instance
order = 2
key = "url"
replacement = "${4}".
result_key = "webservice
With this configuration, I can’t create the instance or webservice tags but, moreover, the telegraf service crashes for a reason I don’t understand
â—Ź telegraf.service - The plugin-driven server agent for reporting metrics into InfluxDB
Loaded: loaded (/usr/lib/systemd/system/telegraf.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since mer. 2020-11-18 13:49:57 CET; 3s ago
Docs: https://github.com/influxdata/telegraf
Process: 1699 ExecStart=/usr/bin/telegraf -config /etc/telegraf/telegraf.conf -config-directory /etc/telegraf/telegraf.d $TELEGRAF_OPTS (code=exited, status=1/FAILURE)
Main PID: 1699 (code=exited, status=1/FAILURE)
Nov. 18 13:49:57 www.mon_url.fr systemd [1]: Unit telegraf.service entered failed state.
Nov. 18 13:49:57 www.mon_url.fr systemd[1]: telegraf.service failed.
Nov. 18 13:49:57 www.mon_url.fr systemd[1]: telegraf.service holdoff time over, scheduling restart.
Nov. 18 13:49:57 www.mon_url.fr systemd[1]: Stopped The plugin-driven server agent for reporting metrics into InfluxDB.
Nov. 18 13:49:57 www.mon_url.fr systemd[1]: start request repeated too quickly for telegraf.service
Nov. 18 13:49:57 www.mon_url.fr systemd [1]: Failed to start The plugin-driven server agent for reporting metrics into InfluxDB.
Nov. 18 13:49:57 www.mon_url.fr systemd[1]: Unit telegraf.service entered failed state.
What do you think I’m doing wrong?
Thanking you in advance
Thierry
