ERR: mixing aggregate and non-aggregate queries is not supported
I set up a weather station with a rain gauge, which is writing data into an Influx 1.7.7 DB.
For this gauge I 'm collecting data into a 7 day shard with a value every 10 seconds.
I set up a continuous query after collecting data for 3 days like this:
CREATE CONTINUOUS QUERY collectd_cq_10min_sum ON collectd_db BEGIN SELECT sum(value) AS value INTO collectd_db."ten_min_sum".rain FROM collectd_db."default".rain GROUP BY time(10m), * END
Now I’d like to get the 3 days into the database as well.
I tried this:
SELECT sum(value),host,region,unit,unit_type,instance  AS value INTO collectd_db."ten_min_sum".rain FROM collectd_db."default".rain where time >= now() - 7d GROUP BY time(10m)
which returns:
If I do this:
SELECT sum(value)  AS value INTO collectd_db."ten_min_sum".rain FROM collectd_db."default".rain where time >= now() - 7d GROUP BY time(10m)
The values get written, but I lose all other information like host and unit. See below:
time                host        instance region unit unit_type value
1563003000000000000                                            0
1563003600000000000 weather     rain     europe ml   volume    0
How can I get at least the host name into the database?
Thanks a lot in advance.
You can try using the “last” function for the host.
Something like
SELECT sum("value") AS "value", last("host") AS "host", last("region") AS "region", last("instance") AS "instance" INTO "database"."retentionpolicy".measurement FROM "database"."autogen"."measurement"')
I don’t know a great deal about CQ’s, i use Kapacitor but the query should be similar. You might not need the double quotes if you’re defining it within Influx as a CQ.
Thank you for your reply.
Unfortunately this does not seem to work.
I tried the following:
SELECT sum(value) as value, last(host) as host FROM collectd_db."default".rain where value <>0 GROUP BY time(10m) LIMIT 2
and got:
time                value  host
1562994000000000000 0.5588
1562994600000000000 0.5588
I tried to replace last() with several other functions which never resulted in a value for the host.
Actually, looking at it. If you are using CQ’s then it might just be a case of grouping by your tags.
I’ve just had a look through here
If think if you group by your tags, or all tags then they should be retained.
SELECT sum(value)  AS value INTO collectd_db."ten_min_sum".rain FROM collectd_db."default".rain where time >= now() - 7d GROUP BY time(10m), *
The difference between this and your original (third query) is the: GROUP BY time(1m), *
I think that might work
How could I not have seen this? The GROUP BY time(10m), * really made the difference.
Thank you very much.
No problem @Rayn0r! You’re welcome.
