Environment variables post v1.38
We are upgrading from v1.36 to v1.40. This includes the “Strict handling of environment variables”
I’m facing trouble using bool and lists environment variables in the configuration-file after this change.
In the “inputs.x509_cert”-input there is an option for exclude_root_certs that is a bool, but I’m not able to make it work.
# cat -n /etc/telegraf/telegraf.conf | grep CERT_MONITOR_INPUTS_X509_CERT_EXCLUDE_ROOT_CERTS -C5
    69
    70  #
    71  # Monitor for the proxy
    72  [[inputs.x509_cert]]
    73    sources = ["${CERT_MONITOR_INPUTS_X509_CERT_SOURCES}"]
    74    exclude_root_certs = ${CERT_MONITOR_INPUTS_X509_CERT_EXCLUDE_ROOT_CERTS}
    75    timeout = "2s"
    76    server_name = "${CERT_MONITOR_INPUTS_X509_CERT_SERVER_NAME}"
E! loading config file /etc/telegraf/telegraf.conf failed: error parsing data: line 74: invalid TOML syntax
# env | grep CERT_MONITOR_INPUTS_X509_CERT_EXCLUDE_ROOT_CERTS
CERT_MONITOR_INPUTS_X509_CERT_EXCLUDE_ROOT_CERTS=false
I also had trouble with the list on line 73, but I just made it a string in the variable.
Telegraf Environment Variable Handling | InfluxData This only covers the “Why?” and strings.
Is there any examples of how to get non strings to work with this change?
The same goes for int.
E! loading config file /etc/telegraf/telegraf.conf failed: error parsing data: line 77: invalid TOML syntax
77    metric_version = ${PROMETHEUS_MONITOR_METRIC_VERSION}
# env | grep PROMETHEUS_MONITOR_METRIC_VERSION
PROMETHEUS_MONITOR_METRIC_VERSION=1
The strict-mode limitation is the non-string values themselves. InfluxData’s migration article says Telegraf first parses the configuration as TOML, then substitutes within string nodes. So the bare ${...} on your bool/int lines fails before the value false or 1 can be inserted. The current command reference also says strict handling doesn’t work with non-string settings.
If those values are fixed for this deployment, the simplest strict-mode version is literal TOML:
exclude_root_certs = false
metric_version = 1
Don’t turn them into quoted strings just to make the TOML parse.
If you need to keep them environment-driven, InfluxData documents --non-strict-env-handling as the opt-out, but explicitly warns to use it only when you trust Telegraf’s execution environment. I’d keep strict mode and generate a valid TOML file with the correct value types instead if that trust assumption doesn’t hold.
For sources = ["${...}"], a substituted string is still one array entry, not a dynamically expanded list in strict mode. Are you deploying via systemd or a container, and does that sources variable contain one address or several? I haven’t tested your configuration on v1.40.
