I am not sure what happened in this scenario.
Any suggestion would be very helpful
Hi ,
That is because you can have a different datatype for the same field per shard.
But not two different datatypes for that field within the same shard.
You will not be able to insert the other datatype untill the shard expires …
If your shard duration is 1h , you can
Insert invalid_age cnt=108i
One hour later you can insert
Insert invalid_age cnt=108.0
This link explains it better …
Field type discrepanties
So basically shard is “data” in a particular time period in influxdb. Am i right?
Thanks!
Yes you are right ,
and that time period is the shard duration defined in the retention policy
Have a nice weekend and don’t forget to check the box as solved
Thank you very much!
You too!
