In the UI when in the “Explore” tab, I can set the format of timestamps and have them include the timezone, which is local time. I don’t see any way to have the timestamps display in UTC. Is that possible?
Hello @n8ur,
What version of InfluxDB are you using?
Under TimeZone in the UI you should be able to select a dropdown and choose between UTC and local.
I hope that helps!
