I know this is something that’s been asked many times but I haven’t located a specific answer that I have succeeded in utilizing. I apologize in advance.
I have a number of weather related measurements being recorded into an influxdb 1.8 database residing on an old RPi1 (hence I can’t upgrade to Influxdb 2.0 currently). Generally the data is valid, but there are some that get decoded wrong and show up way off the scale of reality.
From what I’ve read it appears that it may be possible to delete data by indicating the date/time field as the key. If that’s the only option, I guess I’d have to filter data for values greater than some value for instance:
> select * from "rtl_433/Acurite-Tower/B/temperature_F" where "value" > 100
time value
2021-07-17T02:08:23.968020844Z 905.719982
2021-08-24T16:12:19.944029967Z 1684.0399819999998
2021-08-24T16:37:33.020477072Z 1684.0399819999998
2021-08-24T18:43:36.837907375Z 1695.560018
2021-08-24T19:28:13.296592154Z 1695.560018
2021-08-28T17:12:25.410487174Z 1695.560018
2021-08-28T18:13:22.800103943Z 1695.560018
2021-08-28T18:18:05.406296533Z 1695.560018
2021-08-28T18:40:48.439984996Z 1695.560018
2021-08-28T18:56:19.134400212Z 1695.560018
2021-08-28T19:06:01.166229011Z 1695.560018
2021-08-28T19:22:55.114183116Z 1695.560018
There are between 20 and 50 bad values currently but since they seem to pop up randomly, I was hoping that a simple command or script could find and delete these values without requiring manual intervention. As you can see from the image, I have Chronograf running too in case that would be preferable. If I could be directed to any best practice method, I’ll go with that. Thanks!
