Hello
I need to delet some datas in a measurement
I know the measurement is in Egolzwil
need to delete all
information in Egolzwil
from the 2021-01-28 23:36:30 till 2021-01-29 16:56:30
how to do this correct way?
have a nice day
vinc
Hello
need to delete all
have a nice day
vinc
Please tell us which version of InfluxDB you are using.
Antony.
Connected to http://localhost:8086 version 1.8.3
InfluxDB shell version: 1.8.3
Hoi vinc
Du kannst das in dieser Art lösen, hat bei mir funktioniert (auch V1.8.3) …
DELETE from “mqtt_consumer” where time > ‘2021-02-01T11:36:12.299974334Z’ AND time < ‘2021-02-01T11:40:42.262688206Z’
→ measurement hier “mqtt_consumer”
Gruss aus Oberkirch
Vielen Dank Thanks for your help
