Hi there I wrote some software for that sends data from COLLECTD via csv translation to influxdb. it was working fine. but I update to the newer influxdb 1.6.1 I believe is the version . now my data stops at 2147483647 . where as before it would work fine
the csv format is in this format
timestamp,rx,tx
2018-08-16 22:02:02,578527857,12037843403
2018-08-16 22:02:04,578544624,12037863603
2018-08-16 22:02:06,578558537,12037936331
2018-08-16 22:02:08,578572678,12038036270
2018-08-16 22:02:10,578601072,12038122814
2018-08-16 22:02:12,578603045,12038132742
2018-08-16 22:02:14,578612452,12038157792
2018-08-16 22:02:16,578633138,12038234190
2018-08-16 22:02:18,578646436,12038309756
2018-08-16 22:02:20,578682513,12038339027
2018-08-16 22:02:22,578718635,12038762544
2018-08-16 22:02:24,578759599,12039210691
2018-08-16 22:02:26,578849135,12039818146
2018-08-16 22:02:28,578900611,12040861576
if I restart the counter it works fine again until 2147483647 is reached again
but what I find weird is if I send single values it goes past 2147483647 I tried up to 30 digits without problems example:
timestamp, value
2018-08-16 22:02:02,57852785712037843403
2018-08-16 22:02:04,57854462412037863603
2018-08-16 22:02:06,57855853712037936331
2018-08-16 22:02:08,57857267812038036270
2018-08-16 22:02:12,57860304512038132742
2018-08-16 22:02:14,57861245212038157792
2018-08-16 22:02:16,57863313812038234190
2018-08-16 22:02:18,57864643612038309756
2018-08-16 22:02:20,57868251312038339027
2018-08-16 22:02:22,57871863512038762544
2018-08-16 22:02:24,57875959912039210691
2018-08-16 22:02:26,57884913512039818146
2018-08-16 22:02:28,57890061112040861576
it just when i send 2 or more values are sent at once when it stops working… it use to work fine on previous version just this new version it is not ( not sure what version the previos was but it was downloaded fast fall 1.5.x I suspect )
i tried both windows and linux version of influxdb same issue…
does any one know how to resolve this issue
secondly
how does one download a previous versions of influxdb as a work around as I can not seam to locate links for it
