Dashboard filtering by tag when unset
I may have kind of an impossible request here.
we’ve been asked to make a dashboard that is filtered by a specific tag but sometimes as it’s a migration in progress the tag is not set.
I defined a variable that takes the value of the tag with a simple query ( "show tag values from _bms_metrics with key = “typetrt” where env =~ /^$env$/ " ) but I don’t see how it could take a default value if the tag is not set and then filtering those unset measurements like that… Is it even possible ? Should I take a different path to filter the measurement that have this value set or not set ( and by value if possible ).
Thanks for reading.
Hello @miogi,
What version of InfluxDB are you using?
There are dashbaord variables but they’re not schema aware:
Also what project are you working on with InfluxDB I love to learn about customer/user use cases.
In Grafana…I think you can do something like…
Create a New Variable in Grafana
Go to Settings > Variables > New.
Set the Type to Query.
Set the Name to something like typetrt_value.
Use the following query to include a default option for missing tags:
SHOW TAG VALUES FROM "_bms_metrics" WITH KEY = "typetrt" WHERE "env" =~ /^$env$/
Check the Include All option box. This allows you to select all values including missing ones. Add a Custom Value like No Tag to handle the case when the tag is missing.
Use a Regular Expression for Filtering
In the Regex field, add a regex pattern to filter out tags that are not set:
/.*/|No Tag
I hope that helps! Otherwise I’d ask the fine people over at the Grafana community :slight_smile:
Thanks for taking the time to answer my request.
We’re in Enterprise version for influxdb, Grafana v10.1.3
“Use the following query to include a default option for missing tags:”
=> The query you wrote is the same as my original post, I think you forgot to write yours :slight_smile:
