Patse
July 8, 2021, 10:56am
#1
Hey,
I’m calling all the possible tag values with the following query:
import “influxdata/influxdb/v1”
v1.tagValues(
bucket: "MyBucket",
tag: "Generic_Name",
predicate: (r) => true,
start: -1d
The tag values returned look like this:
“Machine_Number/Name1/Name2/Sensortype/Unit”
What i want to achive is that i cut out the Sensortype and Unit.
I tried to achive this with the strings.trimright() function
https://docs.influxdata.com/influxdb/v2.0/reference/flux/stdlib/strings/trimright/
But i was only able to cut out a specificly defined text. The Problem is that every unit and every sensortype is called differently.
Is there a way to make this trimming funktion dynamical so that it trims everything to the second / from the right?
Hello @Patse ,
Is the front end of your text the same?
You could use regex instead.
https://docs.influxdata.com/influxdb/cloud/query-data/flux/regular-expressions/#examples
I like to use this tester
Regular expression tester with syntax highlighting, explanation, cheat sheet for PHP/PCRE, Python, GO, JavaScript, Java. Features a regex quiz & library.
I found a solution but I don’t like it:
import "array"
import "strings"
word = "Machine_Number/Name1/Name2/Sensortype/Unit"
array.from(rows: [{_time: now(), _value: word}])
|> map(fn: (r) => ({ r with suffix: strings.trimPrefix(v: r._value, prefix: "Machine_Number/Name1/Name2/")
|> map(fn: (r) => ({ r with prefix: strings.trimSuffix(v: r._value, suffix: r.suffix)
I’m sharing with the Flux team too in case there are any other solutions I’m not aware of.
Patse
July 9, 2021, 5:37am
#3
Hey, the front and the back end of my tag values are different for each machine and sensor type.
The only thing that is identical is the number of “/” in between each part of my tag value.
That’s why i hoped that there is a possibility to say trim until the second “/” from the right.
Hello @Patse ,
I think you can say that with regex. I’m just not sure how.
@Anaisdg
I was trying to do something similar, cutting the date off a string x-y-z_20220101 and the search led me to this post.
This doesn’t solve the original problem, but might help anyone else trying to cut the last part of a string containing delimiters, where the string is variable in length:
import "array"
import "strings"
|> map(fn: (r) => ({
r with
start: strings.lastIndex(v: r._value, substr: "/") + 1,
end: strings.strlen(v: r._value),
|> map(fn: (r) => ({_time:r._time, _value: strings.substring(v: r._value, start: r.start, end: r.end) }))
