By default, Telegraf is able to serialize metrics into the following output data formats:
- InfluxDB Line Protocol
- JSON
- Graphite
Is it possible to create our own output data format?
In case, yes how?
Regards
Jef
In case, yes how?
Regards
Jef
For example, I’d like to modify the JSON output format. Is this possible?
It isn’t possible right now, you would need to write a custom Serializer in Go and compile it into Telegraf.
