How do you create a custom check where two fields across two measurements each meet a conditon?
Here’s an example:
import "influxdata/influxdb/monitor"
option task = {
every: 10s,
offset: 3s,
cpu = from(bucket: "system")
|> range(start: -5m)
|> filter(fn: (r) => r["_measurement"] == "cpu")
|> filter(fn: (r) => r["_field"] == "usage_idle")
|> filter(fn: (r) => r["cpu"] == "cpu-total")
|> filter(fn: (r) => r["host"] == "Anaiss-MacBook-Pro.local")
|> last()
// |> yield(name: "cpu")
mem = from(bucket: "system")
|> range(start: -5m)
|> filter(fn: (r) => r["_measurement"] == "mem")
|> filter(fn: (r) => r["_field"] == "used_percent")
|> last()
// |> yield(name: "mem")
data = union(tables: [mem, cpu])
|> group()
|> schema.fieldsAsCols()
|> set(key: "_measurement", value: "cpu and mem")
// the measurement must be in the group key for the monitor.check() function
|> group(columns: ["_measurement"], mode: "by")
// |> yield(name: "data")
data
|> monitor.check(
crit: (r) => r.usage_idle < 95.0 or r.usage_percent < 50.0,
messageFn: (r) => "test",
data: {
_check_name: "mycheck",
_check_id: "0000000000000001",
_type: "threshold",
tags: {},
