Hello
Thanks a lot to all of you who offer support to those in need! Very much appreciated! I have an issue I cannot resolve.
Context
I have a weather station (homematic IP) that for some reason zeros daily sums (e.g. rain) at 0700h and not at 0000h.
Goal
I would like to create a table (used to create a barchart in grafana) with daily sums from 0000h to 2400h.
Already acheived
I already managed to get a cumulativesum of the desired values over a timerange. Works like a charm:
from(bucket: "home_assistant")
|> filter(fn: (r) =>
r._measurement == "mm" and
r._field == "value")
|> difference(nonNegative: true, columns: ["_value"])
|> cumulativeSum(columns: ["_value"])
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "last")
Missing
Now from the above query I woul like to get daily cumulative sum that zeros at 2400h. I figured already that |> aggregateWindow(every: 1d, fn: last, createEmpty: false) returns nice daily “jumps” in the cumulative sum within the time range. But how can I tell the query that it shoud start at zero again every 2400h?
Any ideas?
Thank you!
