this is my first try with influxdb tasks.
So i have my main “mydb”.
Than i have 3 tasks “aggregates5min”, “aggregatesHourly”, “aggregatesDaily”.
Aggregates5min was created on mydb.
AggregatesHourly was created on Aggregates5min.
AggregatesDailywas created on AggregatesHourly.
I am getting data in all my buckets aggregates but i think they are off. Let me explain on temperature example reading.
If i compare MAX temperature reading between aggregates5min and aggregatesHourly i would expect to have the same MAX temp in some period. But this is not the case. In aggregates5min max temp is 65C in aggregatesHourly is let say 62C. So the problem is probably how i create this aggregates.
Aggregates5min from mydb (This one is ok. Correct data.)
option task = {name: "aggregates5min", every: 5m}
data =
from(bucket: "mydb")
|> range(start: -5m)
|> filter(fn: (r) => r["_measurement"] == "sensors")
|> filter(
fn: (r) =>
r["device"] == "raspberry-pi-4" or r["device"] == "water-irrigation" or r["device"]
"weather-station",
|> filter(
fn: (r) =>
r["_field"] == "available_memory" or r["_field"] == "cpu_temperature" or r["_field"] == "waterflow"
or
r["_field"] == "battery" or r["_field"] == "deviceboot" or r["_field"] == "infrared" or r["_field"]
"light" or r["_field"] == "lux" or r["_field"] == "moisture" or r["_field"] == "rain" or r["_field"]
"temperature",
|> filter(
fn: (r) =>
r["sensor"] == "cpu_tmp-1" or r["sensor"] == "cpu_available_memory" or r["sensor"] == "flow-1"
or
r["sensor"] == "flow-2" or r["sensor"] == "battery-procent" or r["sensor"] == "battery-units"
or
r["sensor"] == "battery-voltage" or r["sensor"] == "deviceboot-1" or r["sensor"] == "ir-1"
or
r["sensor"] == "light-1" or r["sensor"] == "lux-1" or r["sensor"] == "moisture-1" or r["sensor"]
"moisture-2" or r["sensor"] == "rain-1" or r["sensor"] == "reboot-tmp-1" or r["sensor"] == "tmp-1"
or
r["sensor"] == "tmp-2" or r["sensor"] == "tmp-3",
data
|> aggregateWindow(every: 5m, fn: mean, createEmpty: false)
|> set(key: "_field", value: "mean")
|> yield(name: "mean")
|> to(bucket: "aggregates5min")
data
|> aggregateWindow(every: 5m, fn: max, createEmpty: false)
|> set(key: "_field", value: "max")
|> yield(name: "max")
data
|> aggregateWindow(every: 5m, fn: min, createEmpty: false)
|> set(key: "_field", value: "min")
|> yield(name: "min")
data
|> aggregateWindow(every: 5m, fn: sum, createEmpty: false)
|> set(key: "_field", value: "sum")
|> yield(name: "sum")
AggregatesHourly from Aggregates5min
option task = {name: "aggregatesHourly", every: 1h}
data =
from(bucket: "aggregates5min")
|> range(start: -1h)
|> filter(
fn: (r) =>
"weather-station",
|> filter(fn: (r) => r["_field"] == "mean")
|> filter(
fn: (r) =>
or
or
or
or
data
|> aggregateWindow(every: 1h, fn: mean, createEmpty: false)
|> yield(name: "mean")
|> to(bucket: "aggregatesHourly")
data
|> aggregateWindow(every: 1h, fn: max, createEmpty: false)
|> yield(name: "max")
data
|> aggregateWindow(every: 1h, fn: min, createEmpty: false)
|> yield(name: "min")
data
|> aggregateWindow(every: 1h, fn: sum, createEmpty: false)
|> yield(name: "sum")
I have also tried to replace this line:
|> filter(fn: (r) => r[“_field”] == “mean”)
with this line:
|> filter(fn: (r) => r[“_field”] == “mean” or r[“_field”] == “max” or r[“_field”] == “min” or r[“_field”] == “sum”)
but than i get values instead of around 60 let say around 300
So what is wrong if anything?
