Here’s an example so far of what i want to achieve:
//Return Water Temp
RWT = from(bucket: “Bacnet_Network”)
|> filter(fn: (r) => r[“_measurement”] == “048_STEM”)
|> filter(fn: (r) => r[“sensor”] == “470500_AI_1103_STEM_LVL0_CWRT”)
|> filter(fn: (r) => r[“_field”] == “value”)
|> aggregateWindow(every: 1h, fn: mean, createEmpty: false)
|> yield(name: “RWT”)
//Supply Water Temp
SWT = from(bucket: “Bacnet_Network”)
|> filter(fn: (r) => r[“system”] == “470000_STEM_ROUTER_PANEL”)
|> filter(fn: (r) => r[“unit”] == “°C”)
|> filter(fn: (r) => r[“sensor”] == “470000_AV_75_STEM_PWP_CHIL_SWT_XFER_AV”)
|> yield(name: “SWT”)
//Chilled Flow
Flow = from(bucket: “Bacnet_Network”)
|> filter(fn: (r) => r[“system”] == “470500_STEM_HYD_BSMT”)
|> filter(fn: (r) => r[“unit”] == “°C” or r[“unit”] == “g/min”)
|> filter(fn: (r) => r[“sensor”] == “470500_AI_1104_STEM_CWR_FM”)
|> aggregateWindow(every:1h, fn: mean, createEmpty: false)
|> yield(name: “Flow”)
//Need to create new tag and timestamp in database with this calculation
//New Value = (RWT - SWT) * 1.8 * Flow * 500.0 / 1000.0
I look at this solution but i can’t make it work:
Create new column to store calculation of two fields from different buckets .
Any help would be appreciated thx!
Hello @bmenard ,
I would recommend doing the following:
|> filter(fn: (r) => r["_measurement"] == “048_STEM”)
|> filter(fn: (r) => r[“sensor”] == “470500_AI_1104_STEM_CWR_FM” or r[“sensor”] == “470000_AV_75_STEM_PWP_CHIL_SWT_XFER_AV” or r[“sensor”] ==“470500_AI_1103_STEM_LVL0_CWRT”)
|> filter(fn: (r) => r["_field"] == “value”)
|> pivot(rowKey:["_time"], columnKey: ["sensor"], valueColumn: "_value")
|> map(fn: (r) => ({ r with _value: (r["“470500_AI_1103_STEM_LVL0_CWRT"] - r["“470000_AV_75_STEM_PWP_CHIL_SWT_XFER_AV”]) * 1.8 * r[“470500_AI_1104_STEM_CWR_FM”] *500.0/1000.0}))
|> to(bucket:"new bucket")
|> yield(name: “Flow”)
Are hoping to write that value back to the same database?
If so I’d also use the keep() function to just keep the new calculated value, measurement, and time column.
I made some assumptions about your data so it’s possible that this isn’t a perfect fit. Let me know if you run into any problems.
Sadly, it returned a Null value. I post the before pivot and after with new calculated value csv file if it can help you saving me.
Thx for helping me.
Before Pivot:
Result:
simon38
September 9, 2021, 3:29pm
4
I think the problem is that “system” is part of the group key, and therefore the results are grouped by “system” and “unit”. I think you need to change the group key by using the group function before pivoting, maybe simply calling group() to eliminate all keys.
bmenard
September 14, 2021, 2:24pm
5
@Anaisdg @simon38 Thx to both of you it solved my problem!
Anaisdg
September 14, 2021, 3:05pm
6
Of course @bmenard ! Thank you for sharing your solution.
