Hello together, I’m trying to create a query that operates on a given table. The goal is to add a new column val that calculates the difference between the current and the previous value of column _value if the current value is bigger than the previous and _field of the current row is equal to _field of the previous row. The following is a minimal example:
Input:
| _time | _field | _value |
| 2021-10-24 02:00:00 | x | 0 |
| 2021-10-24 02:10:00 | x | 2 |
| 2021-10-24 02:20:00 | x | 1 |
| 2021-10-24 02:00:00 | y | 3 |
| 2021-10-24 02:10:00 | y | 3 |
| 2021-10-24 02:20:00 | y | 4 |
Output:
| _time | _field | _value | val |
| 2021-10-24 02:00:00 | x | 0 | 0 |
| 2021-10-24 02:10:00 | x | 2 | 2 |
| 2021-10-24 02:20:00 | x | 1 | 0 |
| 2021-10-24 02:00:00 | y | 3 | 0 |
| 2021-10-24 02:10:00 | y | 3 | 0 |
| 2021-10-24 02:20:00 | y | 4 | 1 |
How would I achieve this within the Flux language?
